Old March 1st, 2017, 22:31
alexgalexg's Avatar
alexgalexg alexgalexg is offline
Leaking Oil
I change my oil every 4k and it literally saved my truck this time... So before each oil change I get under my truck and grease the joints if they need any. Today while greasing I noticed oil all over my brand new starter. I checked my oil level and found that I was running on ONE FOURTH of the required oil... For now I have just replenished the engine with an appropriate amount of its usual castrol edge. I know the little arm that holds the oil filter is a weak point on the 4.0 but would that massive leak more likely be a bad filter seal or the arm? Also, why would a leak that large not leave any noticeable spots on the driveway?
Old March 1st, 2017, 23:41
emx721 emx721 is offline
Re: Leaking Oil
Most likely the oil filter adapter o rings (very common).
Old March 1st, 2017, 23:45
JeepNoob JeepNoob is offline
Re: Leaking Oil
My guess is bad oil filter adapter O-rings and/or bad distributor/oil pressure sensor seals. Really, there's a lot of crap that can leak on the passenger side of a 4.0. Could even be a valve cover gasket (doesn't see oil pressure with engine off, residual oil from the leak is stopped from hitting the ground by the rest of the crap on the passenger side.) So check all of it. Use the "forward and up" rule, worst case scenario, cleaning all the old crap off real good and dumping in some UV dye works wonders.
Old March 2nd, 2017, 00:12
cherokeefan_1's Avatar
cherokeefan_1 cherokeefan_1 is offline
Re: Leaking Oil
I had a head gasket leak oil from the lifter valley side. The rest of the gasket was fine but leaked oil out the passenger side.
Old March 2nd, 2017, 00:24
Hypoid's Avatar
Hypoid Hypoid is offline
Re: Leaking Oil
It leaks under pressure, while you are driving around.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old March 2nd, 2017, 06:37
90xj06's Avatar
90xj06 90xj06 is offline
Re: Leaking Oil
make sure you don't have 2 oil filter gaskets on it. the old one might have gotten stuck on the engine side and you put the new oil filter over it. i somehow did it once.
Old March 2nd, 2017, 08:23
alexgalexg's Avatar
Re: Leaking Oil
Thanks all, since this engine has been in the truck for less than a year its fairly clean and should not be hard to track down this leak properly today
A/C Leaking feels more like my wallet is leaking... duke183 OEM Tech Discussion 21 May 26th, 2010 18:16
Leaking 91 231 T.C. red91 OEM Tech Discussion 3 November 2nd, 2006 08:37
HELP, M/C keeps leaking! egghead OEM Tech Discussion 9 May 20th, 2006 21:32
AC leaking xjchris98 OEM Tech Discussion 1 May 15th, 2006 20:26
what's leaking DeftwillP OEM Tech Discussion 6 November 4th, 2005 07:36
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
