Old December 8th, 2016, 00:51
Vexumy Vexumy is offline
Grinding noise when put into 4 wheel drive.
I have posted this question on reddit, and they said to come to this website. I have a 1996 Jeep Cherokee Country, inline 6, 4.0 and it is coming into winter time and crazy snow time where I live. The other day i tried putting my Jeep into 4 wheel drive Full Time, and it made a grinding noise. So I put it back into 2 wheel and it stopped. I tried it again to make sure if it was consistent. It is. My owners manual says I can put it into 4 wheel at any legal speed. I only did it at like, 15 because I didnt wanna blow something up. Someone said to try putting the car in N at around 4~ mph, putting it into 4 wheel Full Time, then putting it back into drive. I did that and it made the grinding noise again. After I put it into 2 wheel again, it stayed consistent for a couple of seconds, then I put it into reverse, backed it up a little bit to pull into my driveway, and then it stopped after I put it in drive. Anyone have any clue on what's going on, I appreciate your help.
Old December 8th, 2016, 05:28
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Grinding noise when put into 4 wheel drive.
Here's how the factory suggests you shift the transfer case and I've been doing this since these things were new and I worked at the dealership. Quoted from the owner's manual. The suggestions in CAPS are mine.
"To engage, shift the transfer case lever from 2H to 4H while the vehicle is moving at any legal speed". I LET OFF THE GAS, THROW THE LEVER, TAP THE GAS AND LET OFF.
4L position: " To engage, slow the vehicle to 2-3 MPH , shift the transmission to Neutral, then shift the transfer lever to the right and pull firmly rearward to 4L".
TO SHIFT OUT OF 4L, SHIFT THE TRANSMISSION INTO NEUTRAL WITH THE VEHICLE STOPPED, SHIFT THE TRANSFER CASE LEVER TO 2H, THEN THE TRANS TO D IF YOU HAVE AN AUTOMATIC, OR INTO FIRST GEAR WITH A MANUAL, AND CONTINUE ON.
Revised 11/20/2014
https://www.youtube.com/watch?v=u0Lk2r6OmDw
Old December 8th, 2016, 05:59
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is online now
Have you checked the transfer case fluid?
Old December 8th, 2016, 06:07
ehall's Avatar
ehall ehall is offline
Do you get any grinding in Part-Time when you go from 2WD to Full-Time?
my '91 beater rebuild
Old December 8th, 2016, 06:26
cruiser54's Avatar
Yeah. No kidding....LOL
Old December 8th, 2016, 09:58
I do not get any grinding in Part Time. I actually don't even get grinding in Full Time unless I accelerate.
I checked the diff fluid, I guess transfer case is my next go to.
Old December 8th, 2016, 10:09
ehall's Avatar
It sounds like the planetary differential is probably damaged
Old December 8th, 2016, 12:17
I'd just check at the top fill plug to see if you've got fluid and the color.
But it's possible that transfer case is on its way out.
Old December 8th, 2016, 18:40
ehall's Avatar
The only difference between PT and FT is the engagement on the full-time planetary differential (engaged in FT, locked in PT). Everything else is the same. The differentials do take wear damage and will make noise when it happens, IE the pinions deform or the plastic thrust washers break, etc. You might get lucky and its still rebuildable.
4 wheel drive grinding sean058621 OEM Tech Discussion 14 March 28th, 2009 17:33
noise in 4 wheel drive metalandmud01 Modified Tech Discussion 10 March 5th, 2009 17:30
Grinding Groaning Noise Fixed!!!! this is for anyone with that noise! speedmonkey7 OEM Tech Discussion 27 June 8th, 2007 13:20
Clicking Noise While In 4 Wheel Drive HELP!!! xjhandy OEM Tech Discussion 2 December 18th, 2006 06:43
Loud noise in 4 wheel drive Lunatic728 Modified Tech Discussion 0 November 14th, 2005 05:41
