Old December 7th, 2016, 18:23
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Installing New Lifters w/ Orig./Stock Cam?
Originally Posted by Overland View Post
I would tell people the same, that it's no dice. No surprise when the cover came off and the holes were too small, but then there was that video. I'll pass it along to my friend, maybe he can go back and look again.
How did you count pistons with the head bolted down? I would have counted the rocker bosses.
It could just be that you're a badass member of yore who can see through cast iron. Could be.
LOL, I was in a hurry with that post. I used the surrogate you mentioned for counting the pistons. No, I did not use the force, not this time, LOL.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old December 7th, 2016, 20:21
91Heep 91Heep is offline
I had a GM 5.7 vortec powered vehicle for about a decade.
Noisy lifters is a problem among many of them.
When they started knocking consistently,
I'd replace a quart of motor oil with a quart of ATF for the full 3,000 miles.
Worked well.
Somewhere around 240k I replaced them and the push rods,
Filled the block with desiel and ran the oil pump with a drill, took 17 oil filters before I had clean desiel return.
Slowly flushed it out with oil using the same method.
Sold it to a fella at work, Engine is still kicking it knock free.
Installing aftermarket LED foglight in stock location Zatara Modified Tech Discussion 3 March 1st, 2015 13:26
95 4dr Xj DD 100k orig miles Paintballa0788 SEC For Sale / Wanted Forum 1 January 12th, 2011 06:41
Installing a stock gas tank skid? Muddy Beast Modified Tech Discussion 17 July 7th, 2008 12:56
Spray Bomb orig. Alum wheels bl87xj Modified Tech Discussion 10 June 26th, 2007 23:51
Are stock lifters good for hi performance valve springs? Bender Modified Tech Discussion 3 May 21st, 2004 00:29
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
