Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > PAST NAXJA EVENTS > NACFest 2012
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
NACFest 2012 June 21-24, 2012 at Rausch Creek Offroad Park, PA.
  #46
Old March 20th, 2012, 06:48
bert01xj bert01xj is offline
Re: To-Do List
Originally Posted by bert01xj View Post
my jeep
move up shock mounts on axle
new rear shocks
limit straps
wife's jeep
put lift and tires on Done
tank skid
trans skid
clean inside
fender flares
talk her into taking both jeeps.Done thought it was going to be hard I was wrong
fix rear brake hardline
Build front rear bumpers
  #47
Old March 20th, 2012, 17:40
foxwar71 foxwar71 is offline
Re: To-Do List
-Cut out floor and build subframe and skin it, relocate stock AW4 shifter
-Finish front half doors and trimmed for rockers
-Build rear shock hoops, tie them together and to other stuff, mount shocks
-Build rear bumpstop pads and mount poly bumps
-Finish painting the jeep with a brush
-Make rocker and belly skids, 1/8" plate + 1/2" plastic
-Some sort of seatbelts, probably just gunna run stock ones for now
-PSC hydro assist setup
-Tiddy up brake plumbing and rebleed
-Muffler heatshield/gas tank housing sheetmetal
-Maybe some shorter shackles
-Play with the StaK
-Regrease/hit the instrument panel so my gauges will stay working again
-Shakedown run and some thorough testing
-Try not to flop it, I'll wait til NACfest for that
-Acquire new tow rig possibly
  #48
Old March 20th, 2012, 19:08
chedisme chedisme is offline
Re: To-Do List
Originally Posted by foxwar71 View Post
- Look at jeep.
-wish it was red
-play with cats
-wish it was stick
-eat some candy
-carry heavy stuff
-kick out taillights
-bum rides at NacFest
FIFY
  #49
Old March 21st, 2012, 18:25
CountryXJer's Avatar
CountryXJer CountryXJer is offline
Retired Navy
Re: To-Do List
Daily driver is always "done"!
  #50
Old March 26th, 2012, 10:55
ktm racer 419 ktm racer 419 is offline
Re: To-Do List
make it so i feel that its safe to drive 6 hours there, wheel, and 6 hours back.
make new shackles to lower it
swap out coils to lower it
install one shock
install front shafts
redo exhaust
pull diff covers, inspect, re-seal
cage?
front airbumps?
id say i have a solid weekend of lazily working on it ahead of me. i know i might also be forgetting a few things.
  #51
Old March 26th, 2012, 18:11
XJLI XJLI is offline
Re: To-Do List
finish power steering stuff - done. no assist for now, got a free stock box from a buddy, got my money back from tom. JUST KIDDING. box is good, need to get a working pump. muhhhh
install bumpstops - fronts done
install shocks - done
register and insure it - done
get wheels and tires - got wheels, tires this week
finish the cage/bumpers/etc
get new pass side knuckle+ball joints - done and done
route front OX cable done
tidy up rear brake lines
trim gas tank skid so the 60 pumpkin doesnt smash it
crossmember+skid
shorten front DS done, not balanced enough to do 60mph+ but whatev
install ZJ prop valve - done
  #52
Old March 28th, 2012, 09:09
sheepjeep sheepjeep is offline
Re: To-Do List
install front d44
install 8.8
some how make 37s fit
beef up steering
get tow rig
get trailer
  #53
Old April 2nd, 2012, 09:36
Re: To-Do List
Originally Posted by XJLI View Post
finish power steering stuff - good enough
get wheels and tires - done
crossmember+skid
four wheel drive works, lockers work, steering works, brakes work. as of right now i am ready to wheel.
  #54
Old April 9th, 2012, 06:17
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Re: To-Do List
- DONE Bend up harness bar and X brace for cage, finish weld and paint it (hopefully this weekend)
- Finish building 440
- DONE (surprisingly wasn't that bad haha) Get 440 to fit in engine bay
- DONE - Build motor mounts
- DONE - Modify/ build crossmember, transmission mount, NP205 rear mount
- DONE - Redo traction bar crossmember mount (move to passenger side)
- Build new driveshafts
- Mount radiator, plumb cooling
- DONE - Build exhaust
- T-case shifters
- Center console and transmission tunnel
- Slave cylinder mounting/routing
- New dash and gauges
- Megasquirt and TBI
- Clean up wiring harness
- Seal up/paint NP241/NP205/NV4500
  #55
Old April 12th, 2012, 17:59
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
Re: To-Do List
Originally Posted by ROBZ95Xj View Post
Swap out proportioning valve to get brakes workin 100%
Hope jeep dosnt fall apart during shake down runs
Cage
Truck/trailer
Truck has been aquired :
  #56
Old April 15th, 2012, 19:31
Re: To-Do List
- DONE - Mount radiator
- Plumb cooling
- T-case shifters
  #57
Old April 16th, 2012, 04:08
STROKER's Avatar
STROKER STROKER is offline
<-- A Tribute
Location: in my own little world, jus' dunno where it's at
Re: To-Do List
Guess i will chime in
Lets see
replace shifter cable...
maybe fix hydraulic lines on steering
Load it up on the trailer and drive to rausch.....
STROKER
MJ done...when we wheelin w/4.6 STROKER Friend of Matt #17
RAUSCH CREEK
  #58
Old April 16th, 2012, 13:50
Re: To-Do List
install one shock
redo exhaust
cage?
front airbumps?
new plan:
put axles together
slap axles under j10
fuel inject it
fancy tires
and possibly chop up the bed.
  #59
Old April 16th, 2012, 19:32
Re: To-Do List
oopDate
Originally Posted by chedisme View Post
Put some glass in my hatch
get the bolt for my atlas shifter that fell out at rocktober
lock 60 Done
rebuild king pins and breaks
install 60 Done
build steering
Buy 2 cheap 35" rubbers for 17" rims plans changed
37x14r16.5 IROKs Done
H1's Almost
Lock 14b Done
Gear 14b In Progress
Disk Swap
Install 14b
Support Atlas
  #60
Old April 16th, 2012, 19:36
Re: To-Do List
Originally Posted by Justpunchit View Post
Build traction bar
Cage
Rear disks
Lengthen drive shafts
build another frame side trac bar mount
Front anti-rock somehow...
NAH Ill just sell my jeep and sit home.
Rate This Thread:
My WTB List Mosephus Red River Chapter For Sale/Wanted 6 August 14th, 2011 17:50
Table Mesa Trail List (wish list) CrashSomers Arizona Rockfest 2010 15 March 22nd, 2010 18:22
wtb list green95xj NAC Classifieds 2 April 20th, 2009 15:34
Wish list 88woody Modified Tech Discussion 1 November 21st, 2004 09:16
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
