Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 4 Weeks Ago
ehall's Avatar
ehall ehall is offline
Re: Plan to remove sludge and change seals/gaskets
Interesting thanks. I wonder if he is talking about filling the engine with ATF versus using 10-20%--filling it would certainly beat the crap out of it, which is the stated goal. OTOH he says "wouldn't drive it at all" so I guess he saw real damage from using it too. On the third hand, trannies are nothing but gears and bearings and pure ATF doesn't tear them up... different metals and loads though. I suppose the question is what is worse, blocked passages or scuffed components
Old 4 Weeks Ago
joe_peters's Avatar
joe_peters joe_peters is online now
Paying it forward
Agree, blocked passages and damaged bearings/journals or clean passages and damaged bearings/journals--sort of like that story "The Lady, or the Tiger".
is just like Soylent Green, its the people that make it so good!! 90 2-Dr Sport-I6 4.0 w/zj HD fan clutch, Ford 19# injectors-AX15-NP231 w/1" drop & AA bracket conversion-D30 CAD w/Aussie Locker & D35; 3.73 gears-4.5" lift front & 5.5" lift rear-Bridgestone 31x10.5x15 AT-K&N cone Rusty's intake tube, tb spacer, steering conversion-Hurst shifter-5-90's cable upgrade-Terraflex disconnects-adjustable track bar-drop pitman arm.
Old 4 Weeks Ago
hupo224's Avatar
hupo224 hupo224 is offline
The oil I bought just said "sae 30" I'm going to pick up the same oil (shell rotella) but in 15w40. Should make her a bit more quiet I hope
Also my oil pressure goes anywhere between 20-60 psi
Old 4 Weeks Ago
hupo224's Avatar
Still kind of loud. Hopefully time with this new oil and rislone will help
Old 6 Days Ago
Stumper92's Avatar
Stumper92 Stumper92 is offline
I just thought I would mention, based on your photos showing the oil filter, the O-Rings for the filter adapter (both upper and lower) appear to be leaking. I can tell you from experience the oil leaking around those O-Rings will run to the back of the motor and appear to be a rear main seal leaking. For 5 bucks from the stealership you can get the kit and replace those O-Rings pretty easy. I did not get to hear the video, but I also know these 4.0s tend to get a little piston slap when they get up in miles and years. I would be careful how much "flushing" I would do to this engine. Sometimes the sludge is whats holding things together and you can create more leaks and cause bearings to spin. Just my 2 cents.
replacing seals & gaskets? cracked-butt OEM Tech Discussion 15 03-31-2010 20:10
best gaskets and seals? Ethanbjork OEM Tech Discussion 6 10-12-2009 04:56
Various seals and gaskets for grabs davidb0986 Colorado Chapter 0 05-29-2009 15:16
What seals and gaskets to replace? Tyquan OEM Tech Discussion 3 12-25-2007 14:22
Looking for AW4 gaskets and seals old_man OEM Tech Discussion 0 02-10-2007 16:57
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
