Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 07-28-2010
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
Re: A smoggin' I will go...
That's great...all the info on this...I called the dealership with great reserve, but, here tomorrow ~50+ for both sets...grumble grumble, smile, smile.
The silver lining here is that I KNEW beforehand that I needed at least one of the vents and I was waiting to do it before I put my brand new (JY) steel tank skid under there. I just didn't even think about that particular piece flunking my smog test. So now I have another %^!@#$ project...yay!!
Thanks guys!!
I don't know if I know anything at all, but I sure know I don't know everything.
1990 XJ, 4.0, AW4, Open Cooling, 3.5" full pack. Bunch of other mods.
1988 MJ, 4.0, 5 speed, open cooled, work in progress. The MJ project: http://www.comancheclub.com/forums/v...hp?f=7&t=22382
Old 4 Weeks Ago
ParadiseXJ's Avatar
Originally Posted by Saudade View Post
You mentioned you changed the canister lines. I did on mine as well before smogging last month. I noticed one of the lines had a small restrictor in it. It went into the nipple on the canister, but it pulled off with the hose. Luckily I saw it and put it back in. Not sure what effect it has but it listed in the parts guide as a metering plug.
It's an 0.050 metered orifice BUT in the Hayne's manual (I know, I know) the .050 orifice is in the small hose. I found mine in the larger hose. I'm befuddled as to it's REAL location. I don't even know if it makes a difference which side it's on. I think it's purpose is to only allow just enough vacuum to clear the tank of fumes or just enough the charcoal cannister can take, even in a "low vacuum" situation as it's not hooked up to the vacuum reservoir and relies only on intake vacuum.
Anyway I replaced the vent/rollover valves, hooked it all up, ready to try smogging again. I only had to drop the tank about 1/2 way to reach the valves.
My original numbers were great, the only snag was the tank pressure:
At idle - CO2=14.4 02=0.3 HC = 32 CO = 0.16
At 2500 RPM - CO2 = 14.5 02 = 0.1 HC = 29 CO = 0.17
Old 4 Weeks Ago
joe_peters's Avatar
joe_peters joe_peters is online now
Paying it forward
According to the emissions label the orifice should have the line the runs to the fuel tank, not the line to the intake.
And good luck on the test--don't stay up all night cramming for it, old fart!
is just like Soylent Green, its the people that make it so good!! 90 2-Dr Sport-I6 4.0 w/zj HD fan clutch, Ford 19# injectors-AX15-NP231 w/1" drop & AA bracket conversion-D30 CAD w/Aussie Locker & D35; 3.73 gears-4.5" lift front & 5.5" lift rear-Bridgestone 31x10.5x15 AT-K&N cone Rusty's intake tube, tb spacer, steering conversion-Hurst shifter-5-90's cable upgrade-Terraflex disconnects-adjustable track bar-drop pitman arm.
Old 4 Weeks Ago
ParadiseXJ's Avatar
This old fart passed smog today. Everything was tight. Now I can sleep (except for the numerous spontaneous naps I take throughout the day which my employer doesn't even know about).
Old 4 Weeks Ago
joe_peters's Avatar
Paying it forward
This old fart passed gas today, but I blamed it on the dog.
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
