Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 02-09-2010
nicksjeep's Avatar
nicksjeep nicksjeep is offline
231 upgrade
im looking into going to a 4to1, doubler or some way to lower the gears for the tcase. what is the best option? can i go to a diffrent tcase like a d300 or one out of a rubi? i want to go cheap and easy if that is even possible. i have looked around the web site but dont have a full understanding of it all. i would appreciate the advise
Old 02-09-2010
RCP Phx RCP Phx is offline
Re: 231 upgrade
4:1 doesnt come cheap, New they are pretty pricy..............
Tera kit@1100
Atlas@2300
NV241OR@1800
You could still do a doubler or a flipped 300,dont know the $.
Old 02-09-2010
METAL MONKEY's Avatar
METAL MONKEY METAL MONKEY is offline
Re: 231 upgrade
There are quite a few used 241s on car-part.com if you do a nation wide search for under $1200. Also, there is a new one on ebay for $1500.
"Do or do not... there is no try", Yoda
Old 02-09-2010
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
Re: 231 upgrade
I think the best way to do this is be patient.
Check here, Pirate, and other boards classified sections, and you can occasionally find 4:1'ed 231s or 241OR's for under $1000.
Just be willing to wait for it.
John V.
1994 XJ 4.0L, AX15, Ford 8.8", 4.10's, 31" BFG AT's, RE 3.5" Superflex. Locked front, LSD rear, and some other goodies.
Old 02-09-2010
asp's Avatar
asp asp is offline
bucket o rust
Re: 231 upgrade
a dana 300 flip can be done for sub $200 (including the case itself) if you're crafty... to cut up a 231 and put it in front of a 300, you're looking at the cost of the case + $50-75 (i think...) the only thing i've found with a cut up 231 doubler that i can't seem to find a firm price on is the coupling shaft from the output of the 231 to the input of the 300.
Underground Jeeps
98, blue, 5spd, not going anywhere fast
Originally Posted by RCman View Post
Live and learn. Ain't no fun sitting around doing nothing.
Old 02-09-2010
Re: 231 upgrade
Don't forget the price of new driveshafts.
John V.
Old 02-09-2010
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Re: 231 upgrade
a 241 wont work with your 88 because its a 23 spline input while yours is 21
Old 02-09-2010
nicksjeep's Avatar
Re: 231 upgrade
is that a part i can swap in it to match? and will it bolt in?
Old 02-09-2010
trippled trippled is offline
Re: 231 upgrade
should bolt in. you can get new input shafts here www.novakconversions.com
Old 02-10-2010
Re: 231 upgrade
They dont make any other input gears for the NV241OR!
Old 02-10-2010
Re: 231 upgrade
you'd have to swap your transmission.
John V.
Old 02-10-2010
SanDiegoOverland's Avatar
SanDiegoOverland SanDiegoOverland is offline
Re: 231 upgrade
Crazy thought...
How much are gear reduction hubs? (don't know if there is an product for portal boxes for our axles)
also, might want to check out a klun-v underdrive from gear vendors.
not sure on pricing or availability for either of those. Just a thought...
Old 02-10-2010
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
NAXJA Member # 1487
Re: 231 upgrade
Originally Posted by SanDiegoOverland View Post
Crazy thought...
There was a post about that recently. There is a company who makes a portal style adapter for a D44 I think?
I've been in more members' rear ends than I can count.
SOON TO BE A FREE MAN!
Old 02-10-2010
Re: 231 upgrade
yeah that was it, John.
someone either got a narrowed waggy d44 or one of those hen's teeth south american front d44's, and then a MJ d44 and put some companies portal boxes on them...
At least I think that was the application.
since the reduction is downstream of most of the drivetrain, the stock spline count axles tend to be very durable.
Might end up being too much money, but worth a thought if you're going to drop $2k-$3k on a stak or atlas or something like that.
want to upgrade okeedokee NorthWest Chapter 12 09-07-2009 21:42
Upgrade 96 to 99+ Intake. Upgrade injectors, too? BigG OEM Tech Discussion 4 02-07-2007 22:53
RAM Upgrade? XJ Dreamin' Non-Tech / Off Topic 27 08-14-2006 07:43
8.25 Upgrade Roads Modified Tech Discussion 9 04-30-2006 20:08
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
