Old December 4th, 2017, 12:54
anthrax323 anthrax323 is offline
2001 XJ stroker build: keep 0331 head?
My 2001 XJ made it 240,000 miles before breaking a piston skirt. I can say with 99.999% confidence this is the original 0331 head (non-TUPY), as I've owned it since ~110,000 miles. Never had a single issue with it.
Given that it made it this far, is it reasonably safe to assume that I have one of the good 0331 heads? Or should I plan on locating a TUPY or other aftermarket head as part of the build?
Old December 4th, 2017, 14:17
tech1001 tech1001 is offline
Re: 2001 XJ stroker build: keep 0331 head?
If your building a stroker you want more power , I would look at a performance head to add to the power . the stock head is not good for performance even if you do a PNP on the head , the after market head was made to flow better to start with .
Old December 5th, 2017, 10:13
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Check with Russ Pottenger, he can do wonders with a 4.0 head, no matter if it is a 7120, 0630 or a crack free 0331.
He recently supplied forum member RCP Phx with a built 0331 head, along with a stroker kit.
Read about it here. It's quite powerful.
http://www.naxja.org/forum/showpost....&postcount=108
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old December 5th, 2017, 10:19
RCP Phx RCP Phx is offline
I sent Russ a new CCH 0331 head that's supposedly like a TUPY head.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old December 4th, 2017, 14:37
smokeyyank's Avatar
smokeyyank smokeyyank is offline
I'd swap it. No sense in building the rest of the engine and having to worry about possible head issue.
Old Today, 15:00
Did you ever decide what head you were going to use ?
Help me identify this head. I have a 2000 xj with a blown 0331 head. A guy on line sa JeepNovice63 OEM Tech Discussion 11 June 12th, 2017 01:20
Renix head in stroker build PacificEd Jeep Street and Performance 8 February 3rd, 2015 05:02
I need a head (non-0331) in SD 01_XJ SoCal Chapter 3 July 23rd, 2010 15:51
0331 HEAD tugalo OEM Tech Discussion 6 July 22nd, 2010 22:04
question switching from 0331 xj head to 0630 tj head jonnyz123 Modified Tech Discussion 2 May 15th, 2009 20:11
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
