Old November 13th, 2017, 11:57
90xj06's Avatar
90xj06 90xj06 is offline
Yet another heat issue
so as the cold air moves in again. i am left with marginally warmish air.
i also notice that the temperature gauge fluctuates and im guessing thats from when the thermostat opens.
i was reading this http://gojeep.willyshotrod.com/Howto...Restrictor.htm
could this be an cause of the no heat issue?
what are your thoughts on this?
Old November 13th, 2017, 12:48
dan1977p's Avatar
dan1977p dan1977p is offline
Re: Yet another heat issue
Before trying to alter how your cooling system works, you should confirm your heater core is still in good shape, blend door is doing it's job and there is no air in the system.
Usually, this is a heater core issue, though.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old November 13th, 2017, 13:35
90xj06's Avatar
I did look into the blend door and heater core. i have an 88 and can hear the blend door opening and closing. and can tell when its switched. and i did flush the heater core twice now. and no gunk comes out and its flowing pretty good. i have a digital thermometer in the center dash and i got about 118 today and it was about 40 out today. on my hours drive to work it still ends up cold in the cabin.
i feel with the renix cooling system the coolant would just go through the tank and skip the heater core.
Old November 13th, 2017, 18:03
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Is the vacuum valve opening up?
When was the last time you put a thermostat in it?
Old November 13th, 2017, 18:49
90xj06's Avatar
ill double check the vacuum valve. it is newish.
i replaced the thermostat last year when i swapped this engine into this jeep.
Old November 13th, 2017, 21:39
lawsoncl lawsoncl is offline
It's been quite a while since my 89 had that stupid crumbly plastic vacuum valve. As I recall it was a screwy design that let some coolant bypass the even when it was open. When I converted to the "closed" style used in the later Jeeps and plumbed directly to the heater core, my heat significantly improved. I measured 140*F air from the vent on high in 30-degree weather.
Old November 14th, 2017, 06:20
ehall's Avatar
ehall ehall is offline
What does the temperature gauge show? Normal to get a ~50 degree drop in temperature from the head to the heater vents. If the engine isn't fully warmed up you won't get good heat.
Feel the heater hoses with your hand. Top hose from the thermostat housing should be hot and consistent. Lower hose return to the pump should be cool when heat is running, and same as top hose when not.
my '91 beater rebuild
Old November 14th, 2017, 15:35
90xj06's Avatar
Today was not as bad. It was 45 out with engine temps between 175-182 and center vent fan on 2 temp 120. It wasn't as cold and raw out today.
Old November 14th, 2017, 16:33
dan1977p's Avatar
Why is your engine temp only getting up to 182?
SeXJ Build Thread
Old November 14th, 2017, 19:27
ehall's Avatar
185 tstat? put a good quality 195 in there
Old November 15th, 2017, 06:17
90xj06's Avatar
for the most part it sits around 175. i wonder if i got the 160 one by accident. any particular brands you recommend? me and the thermostat housing are sworn enemy's.
Old November 15th, 2017, 06:33
dan1977p's Avatar
I never had any issues with my 195* duralast tstat. If you're having issues with keeping the tstat in place when mounting the housing, you can apply a thin layer of rtv to the tstat and mount it on the inset part of the housing or the head (I forget which side has that right now). Just be careful to not block the weep hole in the tstat and use as little as you have to just to make sure it doesn't move. And if the housing isn't flush before you tighten the bolts, the tstat isn't in the right place and you need to restart from step one.
SeXJ Build Thread
Old November 15th, 2017, 07:30
ehall's Avatar
Stant Superstat is my go-to, never had a problem with them. Mopar made a slightly different model for the last couple of years (buy one for a 2001 XJ), expensive but it works well and has a built in breather to let air out.
Old November 15th, 2017, 21:25
JeepNoob JeepNoob is offline
Agreed. I've heard some bad stuff about Stant stuff here, but never had a problem with the Stant cap or 195-degree T-stat I put in my '96. In fact, when I first bought it, I flushed the coolant not long after and installed the Stant stuff while I was at it. 2 years later when I flushed it again, I re-used both.
Old November 25th, 2017, 18:29
90xj06's Avatar
so i swapped out my thermostat today. it was a 195 t-stat. i did swap it out with a new 195 duralast one. i bled the air from the t-stat housing as i have a later one now. i also swapped the ECU temperature sender.
today it was ~60 out and i got the temperature to stay around 182-195. now to see how it does when its cold out.
Heat Soak Issue Quailman OEM Tech Discussion 44 July 3rd, 2017 18:56
yet another heat issue blistovmhz OEM Tech Discussion 9 November 24th, 2010 12:50
a/c heat issue xj_chef OEM Tech Discussion 1 October 26th, 2010 11:18
Finally solved no heat issue Dave Meyers OEM Tech Discussion 15 March 7th, 2010 22:29
no heat issue heavyhopper OEM Tech Discussion 3 December 29th, 2007 22:09
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
