Old November 9th, 2017, 14:50
Slimer Slimer is offline
XJ tries to change lanes when letting off gas
My XJ tries to change lanes or darts when going 40+ MPH on a curve and I let off the gas to either coast or brake. It does it so much on the freeway coming down the mountain that it is a little scary to drive. I originally thought it was just the rear Detroit locker unlocking, but now I think it might be something else.
Any ideas on what to check?
I have a Dynatrac front axle and the Teraflex High Steer Kit and everything seems to be tight. I checked my rear U-Bolts on my Ford 8.8 and they seem tight. This only happens when going around a turn and letting off the gas. During all other times the steering is good and tight and handling is normal.
Is there anyone in Arizona that I could take it to figure this out?
Thanks!
Old November 9th, 2017, 14:51
Re: XJ tries to change lanes when letting off gas
https://www.facebook.com/brearly.mas...4402509276835/
Old November 9th, 2017, 15:56
RCP Phx RCP Phx is offline
It is the locker, I thought I conveyed the same thing to you when we did the test ride(in mine)!
Old November 9th, 2017, 16:02
So if I pull the Detroit and go with an ARB or a Yukon (does Yukon make an air locker for a Ford 8.8?) that will solve it?
Old November 9th, 2017, 17:06
Yes! How's the temp issues coming?
Old November 9th, 2017, 20:41
TRCM's Avatar
TRCM TRCM is offline
Huh.....none of my locker equipped vehicles ever had that kind of issue..............and I've had 3 of them.
Old November 9th, 2017, 20:44
the_weirdo's Avatar
the_weirdo the_weirdo is offline
Ugh
I've got a Detroit in the rear of my XJ and it does it about half the time. Roads that have noticeable tire grooves (mostly due to snow chains or heavy trucks) seem to be the worst. It doesn't bother me too much but I won't let my wife drive it.
I'm not a complete idiot, some parts are missing.
Old November 10th, 2017, 00:10
TRCM's Avatar
I've never had a detroit...maybe that's the issue ??
It does seem every time someone complains about this, it is a detroit..............
Old November 10th, 2017, 07:24
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Hows the temp issues?
Check leaf spring bushings.
Old November 10th, 2017, 08:21
DaJudge's Avatar
DaJudge DaJudge is offline
Mine does this as well. It is caused by the Detroit. Driving with a Detroit is like driving on slippery roads, if you don't do anything sudden and you will be ok.
Bad leaf spring bushings make it worse.
2001 Limited - 4.0, AW4, NP231, HP D30/TruTrac C8.25/Detroit, 4.5" lift, AJ's Rock Rails, other STUFF.
Old November 10th, 2017, 09:21
I got the temp issues under control with the Hesco Waterpump and the Griffon Radiator.
I don't think my leaf spring bushings are too bad, but I know my shackle bushings look a little cracked and dry rotted. I have stock shackles in back and would like to do a shackle relocation, but I no longer have access to the holes in the back of the body to access the bolts in the gas stank skid. To top it off the gas tank check valve is shot and I probably need to change out the fuel pump assembly. When the prior owner did the top chop they welded a section of iron beam across the back blocking the holes where you would put nut strips.
I am somewhat hesitant to remove the shackles based on all the troubles some people have with those bolts. I would like to at least switch to some heavy duty shackles like the Rusty's.
http://www.rustysoffroad.com/rustys-...-shackles.html
Some people have said that what I am describing is typical with a Detroit Locker and others say it is not. I guess I need to get someone else in the driver's seat and see what they think.
Old November 10th, 2017, 10:01
Pelagius Pelagius is offline
I have a locker in mine as well and it does that too. I have noticed that how excessive the "steer" is depends on the air levels in the tires, how well balanced they are and how old the tires are. Mine was getting pretty bad for a while then I got new tires and I can hardly notice it now.
Old November 10th, 2017, 10:49
techno1154's Avatar
techno1154 techno1154 is offline
Well! I don't know? I do not have a locker in my XJ just an ECTED bit it did exactly the same thing for a few months until I completely rebuilt the front suspension, increased the tire pressure close to what is it should be and had an alignment.
Have drag link and track bar different length do not help either.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old November 10th, 2017, 10:13
My tires are in decent condition, but I do run them with pretty high pressures.
Old November 10th, 2017, 10:48
I notice mine more at 60mph +, but it's a auto, more noticeable on a manual. Slimer asked me to drive his but I can only operate a auto!
After TDS, letting everything go at cost. RWKHausSupply SoCal For Sale 3 March 8th, 2012 11:56
odd noise when letting off gas dan302492 OEM Tech Discussion 10 August 22nd, 2008 17:13
not letting me change my email gunthagunth User Support, Questions and Suggestions 2 February 15th, 2006 17:38
Just letting off some steam theslacker Non-Tech / Off Topic 0 March 26th, 2005 22:16
Thank you for letting me serve Andy Steiner SoCal Chapter 4 March 3rd, 2005 12:33
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
