Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Old January 14th, 2014, 15:32
JeremyB's Avatar
JeremyB JeremyB is offline
6.0 LS Swap
The swap has started.
2000 6.0L LQ4 and 4L80E in to a 2000 XJ. Headers and engine mounts should be here Thursday.
I know there may be better options, however this is a budget build (I have a hard time saying BUDGET on this project) and I got a deal on the engine and tranny. I am taking my time working on it in between customers cars, so this may take some time. I will do my best to make this as clean of a swap as I can.
This is what I started with. (Yes that is a 2wd 4L80E, I will be converting it to 4wd).
Repairing the 3 exhaust manifold bolts.
After new gaskets and some paint.
Trimming the intake.
Waiting on the headers, mounts and oil level sensor plug from Novak.
Old January 14th, 2014, 16:00
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Re: 6.0 LS Swap
I hope you replaced the knock sensors while you had the intake off.
I like orange.
Do you have/planning on running a cowl hood or hood spacers? The intake still looks too tall to fit.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old January 14th, 2014, 16:05
JeremyB's Avatar
Re: 6.0 LS Swap
I like orange.
Yes I did replace the knock sensors. And I will be running a cowl hood. The truck intake is too tall. I did not want to loose the torque or spend the money to convert everything to a car intake and accessories.
Old January 14th, 2014, 19:39
yossarian19's Avatar
yossarian19 yossarian19 is offline
Re: 6.0 LS Swap
I am real, real excited about this one.
If I ever get around to LS'ing the XJ, I'll probably go 5.3 / 4l60e (budget) but the 6.0... you are going to love this thing.
Planning to go to Novak for the radiator, too?
Old January 14th, 2014, 19:50
JeremyB's Avatar
Re: 6.0 LS Swap
Yes. Just have to save up for it.
Old January 15th, 2014, 06:58
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
Re: 6.0 LS Swap
Originally Posted by JeremyB View Post
Sexy!
Old January 15th, 2014, 07:25
jamiemac jamiemac is offline
Re: 6.0 LS Swap
You might be able to trade that 4L80 for a 4L60e. It would make the install easier, I bet.
Old January 15th, 2014, 08:48
JeremyB's Avatar
Re: 6.0 LS Swap
I still might. The plan is later down the road to swap the cam and heads to get closer to 400hp. The 4L80E would be the better trans if I follow through with it. I may be happy with 300hp.
Old January 15th, 2014, 17:26
Vanimal's Avatar
Vanimal Vanimal is offline
Re: 6.0 LS Swap
i thought the lq4 only needed a cam swap to make real nice power?
Originally Posted by GSequoia View Post
I always remember to brace myself before doing moderately tight work and get off when really cranking.
Old January 15th, 2014, 17:55
JeremyB's Avatar
Re: 6.0 LS Swap
You can make big power with a cam. Even more with some heads. The main reason I want to swap heads is this is a 2000 LQ4. 1999-2000 had iron heads.
Old January 15th, 2014, 14:18
Piece of Fish!
Re: 6.0 LS Swap
The 4L60 should hold up fine though. I'm sure you might even be able to find a local to swap that 2wd trans for a 4wd as well?
Some L92 heads and a Z06 cam would be nice.
Old January 15th, 2014, 17:56
Vanimal's Avatar
Re: 6.0 LS Swap
ahh ok
Old January 15th, 2014, 18:26
Frank Z Frank Z is offline
Re: 6.0 LS Swap
4l65E is superior to the 4L60E, 5 Planetary gears vs. 3, and it you won't have to hack up your tunnel to get it in the heep.
Old January 15th, 2014, 19:12
JeremyB's Avatar
Re: 6.0 LS Swap
I will try and find a 4L65E. Thanks! If it was not for you and John D (AKA Godfathers of the XJ LS Swap), I would not be attempting this swap, and for that Thank You.
I'm sure you don't remember me, but we met when I lived in the Springs at a couple of the meets.
Here is the rig I had back then. Pic was taken at Eagle Rock.
Old January 15th, 2014, 19:22
Serious Offroad's Avatar
Serious Offroad Serious Offroad is offline
NAXJA Supporting Vendor
Re: 6.0 LS Swap
Rate This Thread:
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 20:26
5.2 swap into XJ webby1987 Arizona Chapter 11 September 21st, 2011 00:25
NSG-370 Swap in GordoSmasho Modified Tech Discussion 7 May 27th, 2009 07:55
231 to a 242 swap Jeepm@n Modified Tech Discussion 6 June 30th, 2008 07:07
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 12:40
