Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old March 25th, 2011, 23:33
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Boostwerks Build Thread V2.0
Welcome to my build thread!
Iíve been getting several requests to re-build my build thread, so here it is. My beloved XJ is my daily driver, test rig, expedition rig, and in generalÖstress reliever. Itís far from the most extreme XJ out there, but like most Jeep owners I donít think Iíll ever stop wrenching and upgrading it.
99 Sport in chili pepper red
Motor:
Stock 4.0L and AW4
Brown dog MM's with rubber inserts
Boostwerks turbo manifold
Borg Warner T3/T4 57 Trim Turbo
Bosch 43lb injectors
MSD E-coil conversion
AEM FIC 10-1913
AEM UEGO wideband
Tial Billet wastegate and blow off valve
Water to air intercooler
Bosch water pump/aluminum heat exchanger
Auto Meter carbon fiber series gauges
3" stainless down pipe/exhaust
1.5" recirculated dump tube
Trans cooler
Suspension/Steering/Drivetrain:
Dana 30: trussed, true trac, alloys, 4.56s
Chry Co 8.25: home brew U bolt eliminators, relocated shock mounts, detroit locker, 4.56s
rear 11" vented disc setup
Rebuilt 231 with JB SYE and RE driveshaft
1.25" DOM heim'd track bar + brace
1.5" DOM heim steering
12" BBK in process
OME 3.5" front coils + 1.5" spacer
OME rear HD leafs + 1.5" teraflex shackles
Home brew 4 link long arm suspension with 1.5" stretch
Bilstein 5100's
Ruffstuff frame stiffeners
285/75/16 Maxxis Bighorns
1.5" spidertrax wheel spacers
16" Konig countersteer offroads
Other:
Modded Ukrain-Train bumper kit powder coated to match body
Hidden winch mount and remote solenoid
Recessed KC fog's wired to factory fog switch
E auto headlight harness/Autopal lights
Home brew rear cargo rack (best mod thus far)
JCR gas tank skid
Panasonic head unit with JBL component speakers
Kenwood 1000W amp
10" MTX in rear recessed enclosure
Complete sound deadening and undercoating
DOM sliders (not installed)
Let the pics begin!
When I first brought it homeÖ
Front Bumper Build
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old March 25th, 2011, 23:35
Re: Boostwerks Build Thread V2.0
Long Arm Build and Steering Build
Old March 25th, 2011, 23:37
Turbo Build (See the Street Forum for the complete build):
Old March 25th, 2011, 23:39
Axle Build:
Small Projects:
Old March 25th, 2011, 23:41
Random pics
That’s about all I’ve got thus far. I’ll try to keep this updated as much as possible!
Thanks for looking!
Enjoi
Old March 26th, 2011, 06:41
XJLI XJLI is offline
i've said it once i'll say it 1000 times... i effing love those wheels. makes me wanna put goldies on my chili pepper 98
Old March 26th, 2011, 10:43
srmitchell srmitchell is offline
SOOO nice. Love the turbo.
BTW, how do you like those Bighorns?
Old March 26th, 2011, 11:01
Thanks guys. I honestly wish the wheels we're a darker bronze but o well.
The bighorns have been great, except they've started cupping so they're loud as all hell. I can't really blame the tire though because my wheel bearings and ball joints arn't exactly in the best shape. I just havn't had time to swap in my built axles yet.
Other than them being loud, they've been fantastic. Eventually I'll have a trail dedicated set of beadlock wheels and tires, and run an all terrain on the street.
Old March 27th, 2011, 11:53
I'm changing up the exhaust a little bit... I'll have some more pics soon.
Old March 27th, 2011, 12:10
KRONIK KRONIK is offline
subscribed!!!!!!!
Old March 28th, 2011, 17:15
Alrighty. I put the finishing touches on the exhaust today so here are the pics.
I added a 3" Magnaflow Spun Cat, and extended the exhaust past the rear. Before I had it simply dumping out to the side of the leaf spring which resulted in carbon build up everywhere. I'm replacing the plugs in a few days and then heading over to try and pass emissions.
I also had a 3/8" heim joint laying around which has a bronze impregnated bushing (good for high heat) so I decided I'd use it as the rear hanger. Turned out pretty sweet. Since the rear section is fixed I don't need a typical rubber hanger. The heim allows it to move, but still supports the weight. It sounds great and doesn't vibrate!
More to come.
Old March 29th, 2011, 00:37
_87_XJ_ _87_XJ_ is offline
Very nice work!
Old March 29th, 2011, 10:09
CherBear CherBear is offline
Love this build. Awesome!
Old March 29th, 2011, 10:33
Seiler's Avatar
Seiler Seiler is offline
Lookin' good. That's one crazy exhaust tip, I like it!
Old March 29th, 2011, 14:33
Awesome exhaust man.
Think you'll have problems passing emissions?
Rate This Thread:
Boostwerks.com turbo XJ build... Boostwerks.com Jeep Street and Performance 214 July 16th, 2013 07:58
New to the thread/ New build kybray44 Sierra Chapter 5 March 8th, 2010 23:04
ftw or fml build thread toyotawrench SoCal Chapter 31 October 24th, 2009 19:57
The Boostwerks.com Rig build thread... (56k killer) Boostwerks.com Advanced Fabrication and Engineering 97 June 1st, 2009 00:34
my build thread shawnxj Red River Chapter 4 May 10th, 2009 09:28
