    More Information - Join/Renew
whining noise
Mikel
Hello,
My 95 (4.0 5sp) has started to make a wistling whiny noise that is RPM-dependent. It starts as a soft wistle and will go away all of the sudden. I have not been able to point out what's causing it, but seems to come from the A/C pump, alternator or water pump area. The A/C pump is not turning, and turning the A/C on makes no difference. I'm starting to think a bearing in the alternator may be going bad, or maybe in the water pump. But why would the noise go away so suddenly? What could be causing this?
Thanks,
Mikel
I have the same thing, maybe, but I can only hear it in the car while taking off from a light and then cruseing at around 20-30MPH at 1300RMPs. It is very easy to hear and everyone can hear it. It just sound like a light whistle. I have yet to find it.
Check the idler pulleys. They can make a noise that comes and goes. The little flat-surfaced one at the top is usually the first to fail. In my experience the water pump is more likely to rattle, and sound similar to piston slap.
Just for the record, the noise has been gone for the last couple of weeks. I guess now I'll have to wait until something breaks to locate the problem :)
Was your wife in the passener seat? That contributes to a lot of whining noise in my Jeep :D :D
I'm single... Most of the whining I hear stops when I stop the engine :D
