volumeknob
- MI
TJ and ZJ at low pinion. given the age of the MJ, youll want to steer away from that axle even if you find one. and you now know what year XJ axle you are looking for. so... your still looking for an XJ axle.
"finding one is much easier now." :laugh3:
Damn! Thought I was in luck lol
i think where our confusion lies is that it sounds like you have both wants, and needs.
if you need to keep the vehicle on the road... perform the required maintenance on the axle you have to keep it road worthy. if you want to build an axle, and are looking down the road, thats fine. if that is the case, then rebuilding an axle on the bench may be a good stroke of business, so you can work on it as time and budget allows (someone stated this). keep in mind that just because you put good parts on your current axle to keep your vehicle running doesnt mean you cant use them when the time comes to install a more built axle down the road.
This is true, good point. It is a struggle between wants and needs, I think we'd all love to have built rigs but that's why it's a project, at least in my case. I'll just find the parts I need to freshen it up. Think I'm going to pull the driveshaft and see what that changes road manner wise, would atleast help me key in on what the issues are maybe.... Thanks again man!
