1/4 elliptical rear suspension
I like the systems but they weigh more then a coil type setup and should preform about the same.
Beezil ran it on the rear of his XJ and it seemed to work fine.
well eventually I want to run a different setup in the rear of my XJ, 1/4 elliptical done right is pretty neat, very different. But with the new coil conversions coming out from some of the vendors, it may not even be worth it to try by the time I am ready
i mean anyone on here if you have done it or a 3/4 chime in, id like to see how you guys set it up (for those who did it)
That's not what you asked, you asked if it had been done, and your question was answered.
The advantage I could see of half a spring pack over a coil would be that you could still add and remove leaves from a 1/4 elliptical set up to adjust rate and height.
