View Single Post
  #30
Old November 16th, 2017, 15:20
Rockwood Rockwood is offline
Re: XJ tries to change lanes when letting off gas
Originally Posted by Slimer View Post
So I still have a sway bar up front. Everything seems tight, in fact most everything is almost new, including the Dynatrac axle and Tereflex steering up front. The only part of the suspension that I could find that is old is the rear shackles are original and it looks like the upper shackle bushings might be bad. I am replacing the shackles soon. Other than that, I have no idea what it could be.
Physics. Locked diffs make shit go straight. You naturally add steering to force it around a turn. When you remove the reason you needed more steering, you "change lanes".
