What does this burnt plug go to.
Intellect
Tampa Florida
95 4.0 4wd cherokee , my 4wd light/abs light/check engine light stopped working recently and i smelt smoke... Im fixingthis either way, but curious what its for. I went to cut it to splice and i heard a buzz like a door buzzer lol (forgot to disconnect battery which im doing now)
Sent from my Moto G (5S) Plus using Tapatalk
The connector is the headlamp delay module, C233.
#1 White/blck and White/Orage are fused ignition switch output.
#2 Tan/black is headlamp switch output
#3 Black wires are ground
#4 Gray/Orange is fused B+ 12 volts.
You got the right fuses in there? Shorted headlight maybe?
