Tap gas pedal = thump / clunk
macrat123
phily
Hello, I have searched but i couldn't fine anything.
I have a 99 cherokee sport with 98k miles, 231 xcase, and 8.25 rear differentials. I am getting a thump, what seems like right under my seat whenever i tap the gas pedal or release the gas pedal.
It will do it whether i am going 5mph or 60mph. I could be accelerating, release the gas pedal = thump, then i press on the gas pedal again = thump. This noise underneath my seat is driving me crazy.
The front and rear u-joints are tight. So, I don't know if its my driveshaft making the noise whenever my engine is engaged.
Pretty much, whenever the engine is engaged and some torque is applied to the transmission, i get a thunk/thump. Its loud enough for me to notice and feel.
Anyone with a similar situation??? Thanks!
Motor mounts or transmission mounts.
yep. mine did the same thing, if it clunks when you let off the gas its the trans mount, but the XJ motor mounts are notorious for crapping out too.
have the exact same problem, just that mines an 88.. let me know if you end up replaceing the motor mounts, if that corrects the problem. I myself will be replacing the t-mount.
Nav
Mine does the same thing....same year and just about same miles as you too (i'm comin up on 96K probably tomorrow). I've found that slowly applying or releasing the skinny pedal makes a big difference in it.
I dont think its the motor mounts, but the tranny mounts are certainly a possibility.
hmmm... I did have my tranny mounts replaced. However, it was done at Midas. Stupid i know, but i learned from it and tried to do my own work after that.
I'll try to see if the bolts are all correctly torqued. I was thinking about buying brown dog motor mounts. But before i do this, anyone with a similar problem fix it??
I have the same problem with my 01 with a 5 speed. I never minded it much but it's gotten worse. After going with the MORE motor mounts and replacing the tranny mount, I didn't notice it getting better.
I think it's more likely that it's slop in the rear driveshaft. Search for "driveline clunk" and you'll get a decent number of hits. Some people say greasing the transfer case output shaft fixes it, but going with an SYE is probably the better option.
I think I just decided that I'm going to install the AA SYE sooner rather than putting it off any longer. I'll let you know if that fixes the problem if you can hold off for a couple weeks.
I put some grease in the slip yoke but that didn't fix it. Greasing the slip yoke fixes a thump when you accelerate from a stop i think.
This is related to a thump while you hit the gas pedal while you are allready moving. I checked out my motor mounts tonight and it difinitely has play. So i am replacing it with brown dog motor mounts.
Either way, please let us know if that fixed your problem. it didn't fix it for me.
I have replaced my motor mounts. Although it was cracked, it did not fix the clunk/thump problem while pressing the gas pedal and releasing the gas pedal while driving.
I greased the slip yoke, so that didn't fix it either. I'm really stump on this. Any of the previous posters fix the problem?
ToddXJ? did you fix it by putting SYE in?
Its not the SYE i have one and still have the problem. If you put it in Nuetral and rev the engine that would tell you if its motor mounts right?
Check how much clearance you have below the exhaust pipe above the trans/t-case crossmember. When these Jeeps were new they had that problem from the factory. If the mount is good, see if you can loosen the exhaust at the manifold and push the pipe up to gain clearance . Then retighten the manifold flange bolts. I have also heated the pipe forward of the mount and pushed the exhaust up to gain clearance.
It truly is a Jeep thing. Remember, that the XJ Cherokee was designed and built with the latest in 1980's technology. Everyday usage and wear increases the gaps in the driveline and wears the suspension bushings, unibody construction amplifies and transmits the normal sounds.
Check the bushings, u-joints and motor/transmission mounts. Don't tap the gas pedal. Oh, and turn up the stereo.
