IT'S ON TIRES!
On the back at least. Also still a bit of work to do but now at least I can get rolling on the mid stiffeners and then the front. :thumbup:
Couple things I need input on from the braniacs at
1. The mounting of the rear brake line to the caliper; it needs to be a right angle by the way the lines are routed (like normal, FWIW), the right angle is too big to thread in, it runs in to the caliper it self. I found a 1 1/2" NPT thread "Spacer" - would there be any issues with this? I am also going to pose this question to Wilwood.
2. The Iron Rock Truss would not let the brake line junction box mount forward facing. The lines run in to the truss. I remember a brief conversation on this when we welded the truss on and I know we enlarged the hole pretty good but it still won't fit. I soft mounted my extended lines and *looks* like it will work. What say
3. Is this too much bolt sticking out? It bugs me so I'll probably change it either way but is there a potential issue running them like this?
______________
Overall it was a productive day. Couple other little snags along the way but hey it's a Jeep thing. The TNT hardware on the ubolt eliminator kit is to small for Deaver springs, the packs are too tall - I'll have to get 8 bolts and nuts - the kit didn't come with lock washers but I think I should run them - what say
Here's this "finished" product:
Final specs: XJ 44, TNT Ubolt Eliminators and raised shock mounts, Iron Rock truss, Wilwood big brake kit w/drilled and slotted rotors, ARB locker, 4.88's, 35 spline alloy shafts, Lube Locker gasket, Barmes diff cover bolts, Crane diff cover, custom braided stainless brake lines, all topped off with Top Secret coatings primer and black satin paint.
I "borrowed" Kittrell's 35's, this will be the identical tire I will be running. I'm so f'ng excited.
