View Single Post
  #9
Old January 3rd, 2007, 07:14
CAVE's Avatar
CAVE CAVE is offline
Re: My unibody "stiffeners" .......... frame rail strengtheners upgrades tie in
I dont remember exactly the angle measurements, but the two notches are made approx. 7 inches apart measuring from the bottom of the notch. I think I made mine with about a three eights gap at the top of the notch which will bring the angle pretty close. The total length of each side is 5 feet which will leave you a little extra to box around the rear spring hangers. I made my first notch at 2 feet if I remeber right and the second one 7 inches from there. Hope that is enough to get you started, but make sure to make your own measurements once you get your material.
