    More Information - Join/Renew
New here, first post. "brake lines/hard lines"
resisfutal
Hello, I have serched the forums for the answer to my problem and can't find it. I need to replace the hard lines for rear brakes on my '98 xj. Is there a place to get oem lines or do I have to make them myself?
98XJeep said:
it's easy to make them yourself, and prolly cheapr too
If you have a double flaring tool it's easy- if not they will probably leak. While you're there you may as well get the extended stainless braided brake line that you will need in a couple months with the lift.:rolleyes:
