thermostat housing bolts
DieselSJ
QC AZ
1991 4.0
Bolts were pretty rotted so of course one broke when I was torquing it. I thought I'd just hit the dealership for replacements but nope...discontinued and they could not even tell me what size.
Anyone happen to know what size they are? If I was smart I would have measured or brought them with me today, but I figured the dealer would know the size. I want to hit up the bolt place on the way home, so if anyone has the size I'd greatly appreciate it.
Thanks!
Mark
you don't still remember that size do you? The place I took my head in for a valve job lost it and I don't feel like dealing with them to buy me a new one... the bolt I don't have is the long one (upper right)
just added info in case anyone else searches for this... i found a thread on another forum that has the info after i searched the specs you gave me:Upper thermostat bolt: 5/16"-18 x 1-1/2"
Lower thermostat bolt: 5/16"-18 x 3/4"
If you use SS studs and loctite it will make things easier next time.
x2, I would after working with water and metal, definitely go with Stainless if they are available.
Home Depot has stainless steel hardware. Not sure about studs but the bolts are under the eye hook section between the lag bolts + carriage bolts and the bins of specialized hardware (grade 8 is here) at my local store.
