What dose as stock dana 44 look like
Jeep 250
I was at the local u-pull it and think I found an dana 44 in a 94 XJ. Is this possable? It is kinda round but octagon. Looks bigger around than the 35. Is their some way that I can ckeck the vin id? The last time I bought an compleat frount end it cost my $150. Is this worth looking into?
Dennis
Here is my xj 44
to the best of my knowledge they only put 44's in 87-89, Very unlikely to see one in a 94 unless it was swapped in...
It will most likely have 3.55 gears. Are you sure you have 3.07 gears? What year is yours and what drive train?
Brett
Since it's from a 94, it is a 27-spline 8.25, which may not be worth it. The 29-spline 8.25 is more desirable.
You can find the 29-spline in late-96 and later XJs. Glad the pics helped; and thanks for the plug rob.
