odd noise when letting off gas
dan302492
been trying to figure out what this was for a while. while driving usually a bit over 30 and higher it makes an odd noise coming from what sounds to be my transfercase and then when i get back on the throttle it makes a small clunk noise then its gone. sorry for the ill discription. could this be a overly stretched drive chain making that noise after it picks up the slack or the output shaft bearing(does not leak though)??? I know its not the driveline u-joints because i have checked them multiple times.
I would still lean towards driveshaft ujoints.
the same thing happens to mine
it does sound like it is comming from the transfer case
but mine happens when i come to a complete stop and start up again
its like the rear of the jeep is kept up in the air a bit and then suddenly dropped
like the slip yolk isnt doing its job correctly
In your case, all you need to do it take the driveshaft off and grease the slip yoke....it's a fairly common issue....drove mine for a couple years doing that....always thought it was the brakes maybe sticking a little bit. I read about it on here and had the DS off changing a ujoint, slapped some grease on the output shaft and put the DS back on and the "thump" went away.
if you're talking about what I think you're talking about, it seems like some sort of gear backlash in the transmission.
When I'm on the throttle and let off, it kind of clunks back in when I get back on the throttle. I can hear the down shift through the exhaust when it does this.
Mine has done this since it was stock. If it's the same thing, it's not the transfer case because I'm running a different case and it still does it.
All in all I think it's prety cool lol.
Mines a 96 with 110 on the clock and shifts perfectly FWIW, my old 94 didn't do this.
X2 on the slip yoke.
if U have already checked driveshaft & u-joint check your rear diff, I'd similar problem on the diesel one, the pinion nut was a bit loose so no preload and some play on the pinion, I was luky to discover it before destroy my 4.11.....
Unexpectedly, my mystery clunk I've since I dropped my t/c might be solved. Gracias people. I guess it's time for an sye. Dropping the case cured the vibes but I've had clunk with the drop feeling ever since. I changed the mounts, retorqued u-bolts, shackles, etc. It only happens when taking off in a straight line at brisk acceleration & only occasionally so I've living with it. I'm replacing my springs in the near future & figured that would cure it but I'm going to try grease on the yoke tonight!
